I have two issues with my KitchenAid electric range model #KESC307HWW8.
1. I boiled over some water and now the display panel is blank. The touchpad still works, just no display. I believe that the control board needs to be replaced? - Part Number: AP3176181
2. When cooking a heavy pot of potatoes, the glass cook top cracked and needs to be replaced. -Part Number: AP3837477
The question is, can a homeowner do these repairs? and where can I find instructions to do this
The board may not need replacing. Have you tried unplugging the unit for a couple minutes to see if it will reset? If it still does not work, I would unplug the unit and open it up, then dry the board off with a hair dryer. Could be that there is just some moisture between a couple tracks or part connections and that is dropping the voltage to the display. See the attachment for the tech sheet. Here is a manual which should help with the repair. http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=160 |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The board may not need replacing. Have you tried unplugging the unit for a couple minutes to see if it will reset? If it still does not work, I would unplug the unit and open it up, then dry the board off with a hair dryer. Could be that there is just some moisture between a couple tracks or part connections and that is dropping the voltage to the display. See the attachment for the tech sheet. Here is a manual which should help with the repair. http://appliancejunk.com...wnloads;sa=view;down=160 I reset it, it didn't work :mad: still no display - I'm going to have to replace it
