207 Pages«<147148149150151>»
darylp
#1481 Posted : 13 years ago
darylp
About 5 hours.
#1482 Posted : 13 years ago
Originally Posted by: darylp Go to Quoted Post
About 5 hours.
How it's now?
darylp
#1483 Posted : 13 years ago
darylp
the bottom section is still frosting/icing and the top section still has nothing.
drdkdd
#1484 Posted : 13 years ago
drdkdd
Using the diagrams, I'm not locating the defrost timer for my model. Maytag MBF2256HEW. Please help.
#1485 Posted : 13 years ago
The defrost heater assembly consists of two heating elements (#230 at the diagram). One is on the bottom of the evaporator and the other one is located in the middle of the evaporator, right above the frost. You may want to check the bottom heating element for continuity. Make sure there is nothing wrong with the wires connected to the heating element.
- The defrost heater assembly Part number: AP2071465
#1486 Posted : 13 years ago
The defrost cycle in this refrigerator operated by the electronic control board (#5 at the diagram).
What exactly is wrong with your refrigerator?
Here are the breakdown diagrams and Replacement parts for Maytag MBF2256HEW REF - BOTTOM MOUNTS | AppliancePartsPros.com
darylp
#1487 Posted : 13 years ago
darylp
i replaced both of these. the bottom element glows bright orange when on. the top element seems to only have half of the intensity of the bottom.
#1488 Posted : 13 years ago
Does the fan in the freezer work properly?
darylp
#1489 Posted : 13 years ago
darylp
the fan seems to work fine. could it be low freon?
darylp
#1490 Posted : 13 years ago
darylp
maybe it is not the defrost at all. ice freezes in the freezer. but ice cream does not freeze hard like it does in my big freezer. almost everything is cleaned out but the freezer doesn't seem to get below 20 degrees.
Guest (6)
by mrhoagie 12 years ago
by rzeune 14 years ago
by allemich 16 years ago
