I have a Whirlpool aircleaner model#AP51030K that has a warped plastic blower wheel making a loud noise. What special tool is required to remove the 4 screws connecting the back cover. Also, I can't locate any parts information that shows availability of the motor or blower wheel. Is this thing supposed to be a "throw away item"? Thanks in advance for any help!
I am not sure but they are probably Torx. See the below. Torx - Wikipedia, the free encyclopediaYou should be able to get a handle and some Torx bits for 10 to 20 dollars. If you can get the ones with a hole in the center. Just makes the more universal. This type is often used by electronics manufacturers and is s security Torx. The torx bolt has a pin sticking up in the center of the torx female. |
THIS FORUM IS DEAD!!!!!!! |
