bryan b
#1 Posted : Friday, May 23, 2008 6:18:07 PM(UTC)
bryan b
I have a Kitchen Aid Ice Machine model# KUIS18NNJW4 that is giving me nothing but a fit. The problem is while the machine is running and making ice after the cycle is over the pump will continue to run making a sound like it is sucking air. When you turn the machine off and back on it will start the samething over again. We had it checked and the repair man said it was the pump. So we replaced it and that didnt fix it. Next we were told to replace the circuit board that it wasnt giving the comand to the pump to turn off when there was no water. Replaced the circuit board and same problem exists. What can be done to fix it?
ApplianceJunk
#2 Posted : Friday, May 23, 2008 9:06:50 PM(UTC)
ApplianceJunk
Hi,
When was the last time you cleaned it?
What happens with these is the plate that freezes the water gets dirty.
Then the sheet of ice does not slide all the way off to the grid to be cut into cubes.
The sheet of ice makes a bridge between the plate that makes the ice and the grid that cuts the ice.
The water then starts to run accross this bridge of ice instead of through the pump like it should be and that is were you are getting the sucking sound.
I would read the instuctions for cleaning the ice maker and run a bottle or two of ice machine cleaner though it.
gregg
#3 Posted : Monday, August 4, 2008 4:56:02 PM(UTC)
gregg
I would replace the water inlet alve as it sounds like it is not working. I had the same problem and it is working fine.
jackmcmanus21
#4 Posted : Monday, August 25, 2008 11:18:35 AM(UTC)
jackmcmanus21
thanks for the tip Mike
mikew
#5 Posted : Sunday, March 8, 2009 12:05:33 PM(UTC)
mikew
Hello,
I am having a similar problem and have had for 5 yrs - that is how long I have lived in this house, the unit is 8.5 yrs old. It will make ice like no tomorrow for 6 months and then do what you are talking about. We have cleaned and cleaned - sometimes it works and sometimes you just turn it off and on, over and over again and it will usually work - sometimes this takes a few weeks
This time however, the tank seems to be low on water, the pump 'chugs' and the ice that is formed does not drop off of the plate, it will only make ice on the initial startup. Today I have confirmed that all of the devices work with the test equipment available to me.
Did you change the supply water valve as was recommended?? If so, did that fix your issue?? Any help would be appreciated
gregg
#6 Posted : Sunday, March 8, 2009 6:30:58 PM(UTC)
gregg
Mike, these things can be tricky and aggravating. the water inlet valve was the answer for mine. They get dirty and do not work properly. If the pump is sucking air then it is not getting water. The water valve cost a lot less than the circuit board and the pump.
dgdl441
#7 Posted : Monday, September 13, 2010 9:44:42 PM(UTC)
dgdl441
Online shopping has been a trend now, so if you want to buy cheap boots isn`t a problem. The important question is what kind of boots style you like, in order to show it in front of your loved person? If so, the best quality and cheap boots is essential. our company Ugg boots not only beautiful but also very good quality,that is why in winter, best choices for women boots must be ugg boots. So where can buy best quality and cheap ugg boots. It is the focus of this article. First of all,the Internet so developed, it is also more stores of ugg boots will dazzling you, right? So hard to get one pairs nice boots to fited yourself. You have to sure your size, color, or even boot`s weight you have to consider too. When you think about the appearance of the boots, then you can start shopping. Here in www.ugg5803.com you can find all the newest ugg boots, and sizes are also able to choose, as long as you know your size. If you want to get big quantity of ugg boots or wholesale ugg boots,you also can choose from www.ugg5803.com. All the ugg boots are designed by the designer, using a high-grade suede material. Also ugg boots been made exquisite, so it can been a birthday gift or Christmas gift too !Their contact email is:service@ugg5803.com.
Kitchenaid Ice Maker Lever Problem (General Talk)
by Guest 11/4/2021 10:00:56 PM(UTC)
Kitchenaid ice maker help (Refrigerator & Freezer Repair)
by Fridge276 7/31/2020 3:09:46 AM(UTC)
KitchenAid Ice Maker won't stop turning. (Refrigerator & Freezer Repair)
by slipsibm 5/30/2020 10:15:54 AM(UTC)
KitchenAid ice maker - ice sometimes slides into reservoir pan rather than onto cutter grid (Refrigerator & Freezer Repair)
by thall88 12/7/2018 1:59:31 PM(UTC)
KitchenAid ice maker not dispensing ice (Refrigerator & Freezer Repair)
by kkranzo 7/6/2017 7:19:23 PM(UTC)
Kitchenaid Ice Maker Issue (Refrigerator & Freezer Repair)
by phillyphan 5/29/2017 1:06:55 PM(UTC)
KitchenAId Ice Maker not working (Refrigerator & Freezer Repair)
by mmciel 12/21/2012 8:28:40 PM(UTC)
KitchenAid ice maker not working (Refrigerator & Freezer Repair)
by lizprimary 12/15/2012 2:42:41 PM(UTC)
Icicle forming underneath KitchenAid ice maker (Refrigerator & Freezer Repair)
by AaronGo 10/15/2012 5:28:19 PM(UTC)
by East Texas 4/25/2012 11:06:10 AM(UTC)
KitchenAid Ice Maker Not Getting Water (Refrigerator & Freezer Repair)
by Steingraber 3/4/2012 12:49:54 PM(UTC)
kitchenaid ice maker not working (Refrigerator & Freezer Repair)
by laurn 12/19/2011 6:44:32 PM(UTC)
Dripping KitchenAid Ice Maker (Refrigerator & Freezer Repair)
by tonymarch 9/8/2011 5:16:52 AM(UTC)
Kitchenaid Ice Maker (Refrigerator & Freezer Repair)
by b015dwj 7/14/2011 5:28:02 AM(UTC)
kitchenaid ice maker (Refrigerator & Freezer Repair)
by hommebr 4/29/2011 12:33:56 PM(UTC)
