29 Pages«<1718192021>»
#181 Posted : Wednesday, February 8, 2012 2:38:19 PM(UTC)
What is the part number of the control board you are looking for?
YoungPadawan
#182 Posted : Tuesday, March 6, 2012 2:02:36 PM(UTC)
YoungPadawan
E6F2 error codes generally mean the control board is on the way out, especially if you're seeing a blank screen. Replacing the keypad or cleaning the ribbon is only delaying the inevitable. But you don't have to buy a new controller (especially since many of them are no longer available). Running a google search for ************************ should lead you to a company that can repair oven controllers.
kodiak23
#183 Posted : Thursday, March 8, 2012 8:18:22 AM(UTC)
kodiak23
Hi Gene -
I am looking to order AP3767567 for my RBD275PDQ8, but I was told it is discontinued. Can you confirm or help me find one? I'd rather get a new one then track down an old one.
Cody
#184 Posted : Thursday, March 8, 2012 4:38:49 PM(UTC)
Hi Cody,
I did search for this part and I found that it is still available but it's on a back order. You have to talk to the APP team to find ETA.
kodiak23
#185 Posted : Thursday, March 8, 2012 5:07:54 PM(UTC)
kodiak23
Hi Cody,
Thanks Gene. I talked to them a couple days ago and they said it was discontinued. Any other ideas on how I could get a board, so I can fix my oven? Or do I need to buy an entirely new oven? Thanks for your help.
machong
#186 Posted : Friday, March 16, 2012 8:42:12 AM(UTC)
machong
Hello Gene,
I have Whirlpool Model # GBD307PRQ01 Similar situation that others have posted. Display goes out mid-bake cycle. Oven heat and light still work. Display comes back slowly. Today error code E6 F2 came on. What steps should I take to determine issue. I have read the thread but want to make sure I do things in the right order.
Thanks for all of your help.
Marcie
#187 Posted : Friday, March 16, 2012 12:46:19 PM(UTC)
Hello Marcie,
Very likely the problem is a bad control board. Especially because of the display which goes on & off.
- The control board Part number: AP4909214
machong
#188 Posted : Saturday, March 17, 2012 4:41:28 AM(UTC)
machong
Hello Marcie,
Is there a way or something to check that might be loose?
#189 Posted : Saturday, March 17, 2012 3:38:37 PM(UTC)
Unfortunately there are no such parts. I understand you point. This part is very expensive, but this is the only way to fix it.
Aimin
#190 Posted : Saturday, March 31, 2012 8:55:52 AM(UTC)
Aimin
Hi Gene,
I have posted this a couple of days ago but maybe you can provide some insight as I have been following you with the repair.
My double oven stop working a month ago. After I have changed thermal fuse and control panel, it worked, for one night! The next morning, it stopped working again. I checked to find out the fuse is out and I remembered that the R90-92 to be hot. So I order a control board and new thermal fuse. I put them back tonight and it worked! However I found that the parts R90-92 were pretty hot, and I am afraid that something else is wrong besides the board. Should these parts be hot? Is there a way to check? Would I not doing the program cavity size cause the problem? Thanks in advance!
Aimin
Guest (14)
Whirlpool fault code E6 F2 (Oven Repair (including Ranges and Cooktops))
by msdabbert 11/26/2009 8:21:35 PM(UTC)
