I had my control board refurbished and installed it tonight. Upon turning the power back on, the unit goes into a pattern of seven short beeps followed by a brief pause. I tried the key sequence for programming the board for the correct oven cavity, but that isn't working. The oven goes into "timed cook" mode and reverts back to beeping after I cancel. Any ideas?
Originally Posted by: safletcher  I had my control board refurbished... Who did it? Double check the wire harness and touchpad connections. If they fine, the control board is bad.
Fix Your Board did the refurb.
I cleaned the ribbon connecting the touchpad to the control board. The beeping stopped and we got an E1F2 error code. Replacing the keypad now...
Whirlpool range/oven Slide in 4.8 touch control ss. No power, control panel dead. 3 3 Months after purchase c.panel would go dead. 2-3 hours back on. After 2nd occurrence, service replaced control board. Now c.panel dead for 48 hours. Circuit breaker reset, 200 v at wall outlet and unit terminal block.
