2bluesuz
#1 Posted : Monday, March 23, 2009 2:28:34 PM(UTC)
2bluesuz
Dishwasher works, but fills with water in the bottom.
I disconnected drain hose and water will fill a bucket
after cycles are complete, but still leaves standing
water up to the door.
Removed drain cover and there is no debris.
NO debris or blockage in 1" white exit hose.
Removes most water but leaves 1" standing
in machine tub at end of all cycles.
No blockage all the way to P trap exit at wall.
I checked the air gap. Washer has it's own exit
(not through disposal).
Hose is at least 32" above floor for air gap.
Checked float and it is moving freely.
It does have a strong flow out.
Could there be a timer problem where it
stops before all water is pumped out?
What could it be?
Thanks!
#2 Posted : Monday, March 23, 2009 5:20:52 PM(UTC)
Here is the parts breakdown
Model Search
Check out Piston & Nut, Item 564 in the "Body Parts" section.
It is under the screen filter at the back of the tub.
It should unscrew.
If it does not seal, it will give the symptoms you describe.
Is a fairly common problem.
2bluesuz
#3 Posted : Tuesday, March 24, 2009 4:24:13 AM(UTC)
2bluesuz
I looked at previous posts and thought that might be the problem.
I took it out and I am going to get a new one today.
Thanks for helping out a "girl" in need!
Suzie
#4 Posted : Tuesday, March 24, 2009 4:26:46 AM(UTC)
My pleasure!
vitaly
#5 Posted : Sunday, February 26, 2012 9:01:57 AM(UTC)
vitaly
My dishwasher has exactly the same symptoms, but the model and parts are different.
What can cause the problem?
Model: GSD500X-72BA
Link to the parts page: Replacement parts for General Electric GSD500X-72BA DISHWASHER | AppliancePartsPros.com
Please help!
vitaly
#6 Posted : Tuesday, February 28, 2012 11:24:45 AM(UTC)
vitaly
Anybody? Please!
#7 Posted : Friday, March 2, 2012 3:57:37 AM(UTC)
vitaly
Please start your own thread using Post New Topic is this forum section.
Your unit is not the same as the original post so requires a different answer.
Guest (8)
GE Profile Dishwasher will not drain completely (Dishwasher Repair)
by michellemb 1/5/2011 8:05:52 AM(UTC)
