bobbyg
#1 Posted : Thursday, March 5, 2009 10:24:12 AM(UTC)
bobbyg
The door is open about 2 inches but will not open any further. Cannot close door either. I think my daughter had stated to run the compactor and then tried to open the door to put one more item in. The compactor is now locked up. Any advice please???
#2 Posted : Friday, March 6, 2009 10:30:30 AM(UTC)
Try to push the door in and restart the trash compactor.
gene.
Kimostrom
#3 Posted : Monday, April 13, 2009 12:28:09 PM(UTC)
Kimostrom
Wondering if your advise worked for BobbyG as my compactor is stuck about 2" open as well today and was in use when it was opened by mistake!
HELP!
#4 Posted : Monday, April 13, 2009 1:18:48 PM(UTC)
HELP!
Did you try to do it?
Kimostrom
#5 Posted : Monday, April 13, 2009 1:56:34 PM(UTC)
Kimostrom
Yes, the door will not close...stuck in position about 2" from closing and the bin is empty so I know that nothing is clogging it up.
We have a GE Monogram ZCGS150 Model
#6 Posted : Monday, April 13, 2009 3:22:57 PM(UTC)
Remove the trash compactor from the cabinet. Put it on its side and remove the bottom cover. Inspect the chain and gears. You can lift the ram up by rotating the main gear.
Kimostrom
#7 Posted : Monday, April 13, 2009 4:30:41 PM(UTC)
Kimostrom
Thank you for the advise....my husband was able to get the door open and reset the switch to get it going again so we're good to go!
#8 Posted : Monday, April 13, 2009 5:05:30 PM(UTC)
I'm glad it was that simple.
marchboom
#9 Posted : Saturday, May 23, 2009 11:35:18 AM(UTC)
marchboom
I have the exact same compactor with the same problem. GE was no help. Followed Gene's instructions (turned the main gear till the ram lifted out of the way of the bin) and the compactor worked again. You saved me some $$$ (service call). Thanks Gene!
#10 Posted : Saturday, May 23, 2009 7:21:38 PM(UTC)
