9 Pages«<56789>
ws6s
#61 Posted : Saturday, February 11, 2012 6:53:31 AM(UTC)
ws6s
no not yet
#62 Posted : Saturday, February 11, 2012 12:37:52 PM(UTC)
Install the new part. Wait about 24 hours and post the results.
ws6s
#63 Posted : Monday, February 13, 2012 11:10:46 AM(UTC)
ws6s
ok 13 degrees in freezer 37 in fridge & fan stopped running ( for now ) ?
ws6s
#64 Posted : Monday, February 13, 2012 3:39:01 PM(UTC)
ws6s
fan is running and freezer is around 15 degrees
ws6s
#65 Posted : Tuesday, February 14, 2012 4:06:25 AM(UTC)
ws6s
this morning freezer 18 degrees fan not running
ws6s
#66 Posted : Tuesday, February 14, 2012 12:41:35 PM(UTC)
ws6s
Now 19 Degrees And Fan Is Running
ws6s
#67 Posted : Thursday, February 16, 2012 10:16:12 AM(UTC)
ws6s
Now The Freezer Is Running Constantly And At 22 Degrees And The Fridge Is At 41 Degrees
#68 Posted : Thursday, February 16, 2012 10:44:12 AM(UTC)
Hi Todd,
I checked all our previous conversations and I did not find any report from you on checking the defrost heater for continuity.
Did you do this test? if you did it what was the result?
If you did not do it yet then do it and post the result.
You can do it from the main control board by doing the following: unplug the refrigerator. Remove the wire from the terminal J9 at the control board and measure the resistance between this wire and neutral (pin 9 on the J7 connector - orange wire). The freezer must be cold at this time.
ws6s
#69 Posted : Thursday, February 16, 2012 4:21:39 PM(UTC)
ws6s
ok took the readings with 2 different multimeters,first one no reading at all 2nd one oc code which is open circuit i guess.???
#70 Posted : Friday, February 17, 2012 12:15:14 PM(UTC)
If you did everything correct and you already replaced the overtemperature thermostat, then the defrost heater is bad.
- The defrost heater Part number: AP3183311
9 Pages«<56789>
