10 Pages«<23456>»
antb2112
#31 Posted : Monday, March 14, 2011 7:49:49 AM(UTC)
antb2112
All done and fixed. Took forever to get the board AND it didn't come with buttons. Used old ones and is good as new!
Thanks, again, Gene!
anthony
#32 Posted : Monday, March 14, 2011 5:55:41 PM(UTC)
You are welcome Anthony. I'm glad it's up and running.
KristenE
#33 Posted : Friday, February 10, 2012 6:42:49 PM(UTC)
KristenE
Hi Gene! I have a Frigidaire PLEFZ398GCC which doesn't heat very quickly at all. It takes about 30 minutes to get to 150 degrees. The broiler doesn't seem to work at all. The stovetop works fine. Your advice would be greatly appreciated!
#34 Posted : Saturday, February 11, 2012 12:59:47 PM(UTC)
Most likely the problem is a bad control board. It is recommended to replace the overlay as well because it is glued on.
- The control board Part number: AP4319715
KristenE
#35 Posted : Saturday, February 11, 2012 4:47:40 PM(UTC)
KristenE
Thank you! In your opinion, is it something a reasonably handy person can do or is it more of an expert type repair.
#36 Posted : Monday, February 13, 2012 2:19:25 PM(UTC)
If you know how to handle a simple tools this is not too difficult job. You can access the control board by removing the rear control panel cover.
AutumnOwen
#37 Posted : Thursday, April 26, 2012 4:01:29 PM(UTC)
AutumnOwen
Gene you seem to be the man around here...
I have Frigidaire model #FEB30S5DCC
Same issues here... Neither the broil element or the baking element come on. So am I in the same boat & need to order the expensive EOC?
#38 Posted : Thursday, April 26, 2012 4:58:54 PM(UTC)
With this model it can be something more simple. Pull the range out of the wall and remove the rear panel. Check the safety thermostat on the back. It is resettable. So, try to push the red button in the middle of it and give it a try.
If it would not help, check this thermostat for continuity. If it's open, replace it.
- The safety thermostat Part number: 318004900
AutumnOwen
#39 Posted : Thursday, April 26, 2012 6:10:09 PM(UTC)
AutumnOwen
Gene. Took it out and pushed the switch. Does not seem to work.
Help a very rookie electrical guy:
"check this thermostat for continuity. If it's open, replace it."
Do I check it with a multimeter? How would I know if it's open?
#40 Posted : Friday, April 27, 2012 6:08:58 PM(UTC)
Yes, you have to have a simple multimeter to do it. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter.
10 Pages«<23456>»
