dmw1209
#1 Posted : Monday, January 2, 2012 7:12:26 PM(UTC)
dmw1209
I have a Kenmore washer model #110.26652500 that will not always run through the spin cycle. The washer fills, agitates and drains consistently but will not automatically go through the spin cycle. If I open the lid and turn the basket then close the lid the washer will generally complete the spin cycle. I have read several posts regarding the no spin issue with this series of a Kenmore so I wanted to find out what the most likely culprit is for this problem. Clutch, brake, timer?? Thank you for any assistance you can provide.
ApplianceJunk
#2 Posted : Monday, January 2, 2012 8:40:25 PM(UTC)
ApplianceJunk
Most likely the timer.
BenjaminA
#3 Posted : Wednesday, January 4, 2012 10:59:51 AM(UTC)
BenjaminA
Did you find a fix to your problem? I have the same problem with a Kenmore series 80. Thanks
dmw1209
#4 Posted : Friday, January 6, 2012 9:40:16 AM(UTC)
dmw1209
I have ordered the part so I should know shortly. I will post another response once the part is installed.
dmw1209
#5 Posted : Thursday, January 12, 2012 4:20:58 PM(UTC)
dmw1209
BenjaminA,
We have replaced the timer in our Kenmore series 80 washer & it seems to have corrected the issue. I have only tested one load so far but it is spinning like a champ.
Guest (5)
Kenmore washer won't spin (Washer Repair)
by KENSAR 9/8/2014 7:17:44 PM(UTC)
by gorogergo 8/23/2014 12:33:47 PM(UTC)
Kenmore Washer won't spin at all (Washer Repair)
by Mealbee 6/29/2014 1:01:14 PM(UTC)
Kenmore Washer Won't spin (Washer Repair)
by CrossWashappliances 2/2/2014 5:10:05 AM(UTC)
Kenmore washer won't spin or agitate (Washer Repair)
by jwes 1/23/2014 6:22:22 PM(UTC)
Kenmore Washer Won't Spin, Drain Properly (Washer Repair)
by TheDude 12/30/2013 11:53:55 PM(UTC)
90 series kenmore washer won't spin, drain (Washer Repair)
by Beckmd 10/25/2013 3:14:26 PM(UTC)
Kenmore washer won't spin, stop agitating, or drain. HELP! (Washer Repair)
by bwal314 7/15/2013 7:00:50 AM(UTC)
by tbditw 2/3/2013 4:52:34 PM(UTC)
Kenmore Washer won't spin (Washer Repair)
by Electechab 1/29/2013 3:43:56 PM(UTC)
Kenmore washer won't spin correctly at times (Washer Repair)
by phillips1978 6/19/2012 6:46:04 AM(UTC)
Kenmore Washer won't spin, agitate or drain (Washer Repair)
by Micky_577 5/14/2012 9:28:00 AM(UTC)
Kenmore washer won't spinj (Washer Repair)
by duckhunter22 3/10/2012 7:23:13 AM(UTC)
by Little old me 1/28/2012 4:22:51 PM(UTC)
by pgarbs 9/1/2011 10:19:22 AM(UTC)
