mabzz4543
#1 Posted : Saturday, December 31, 2011 4:04:52 PM(UTC)
mabzz4543
take off oven door to replace glass now door won't go back in hinges seem to not lock in plus it won't catch the hinge pins please help
ramblinche81
#2 Posted : Saturday, December 31, 2011 8:14:37 PM(UTC)
ramblinche81
Make sure hinges are in the closed position.
Lift the door ABOVE the pins, push door/hinges into slots, then allow door to slip/slide down onto pins.
mabzz4543
#3 Posted : Saturday, December 31, 2011 10:35:05 PM(UTC)
mabzz4543
still not working hinges not conecting
ramblinche81
#4 Posted : Sunday, January 1, 2012 6:39:39 AM(UTC)
ramblinche81
Can you see the horizontal pins on the lower edge inside the vertical opening the hinges slip into the body of the oven ?
Can you see the slot in the hinge on the bottom edge which fits over the horizontal pin ?
You will need to push the door against the body of the oven slightly in order to compress the door seal and allow the slot to reach back far enough over the pin before it drops into place.
Otherwise, call a technician.
mabzz4543
#5 Posted : Sunday, January 1, 2012 9:34:02 AM(UTC)
mabzz4543
now that the door is on the oven door won't stay down when it is in the down or open position just keep wanting to come up have to hold it down in order to take something out. HELP
Viking Oven door opens only 1/2 in. Did not use self -clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 1:50:17 PM(UTC)
Oven door almost opens (Oven Repair (including Ranges and Cooktops))
by hasyed 3/30/2023 1:13:59 PM(UTC)
Maytag wall oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:44:59 AM(UTC)
Frigidaire GLGFS66.ABB Oven Door Sticks at Broil Stop Position (Oven Repair (including Ranges and Cooktops))
by gdaarob 3/28/2022 6:15:15 AM(UTC)
Jennaire JGS8860BDP oven door (Oven Repair (including Ranges and Cooktops))
by df911 11/4/2021 9:38:06 AM(UTC)
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 10/27/2021 5:49:46 PM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
Frigidaire oven door hinge not locking (Oven Repair (including Ranges and Cooktops))
by jacobrobbins219 3/16/2021 5:42:08 PM(UTC)
Oven Door Locked - No Power (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 10/26/2020 3:33:54 PM(UTC)
Samsung - Oven Door Won't Close Tight (Oven Repair (including Ranges and Cooktops))
by Samich 4/26/2020 7:59:48 AM(UTC)
Kitchenaid wall oven door locked (Oven Repair (including Ranges and Cooktops))
by mdawley 3/6/2020 9:40:01 AM(UTC)
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
Where Online Can I Find Compatible DCS (Fisher & Paykel) Oven Door Hinges? (Refrigerator & Freezer Repair)
by WestLA 8/19/2019 10:57:44 AM(UTC)
Replace oven door assembly or outer tempered glass (Oven Repair (including Ranges and Cooktops))
by Jkaup 6/15/2019 8:29:47 AM(UTC)
Oven Door still will not close after hinge and seal replacement (Oven Repair (including Ranges and Cooktops))
by Ten13 3/18/2019 8:45:03 AM(UTC)
