take off oven door to replace glass now door won't go back in hinges seem to not lock in plus it won't catch the hinge pins please help
Originally Posted by: mabzz4543 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) take off oven door to replace glass now door won't go back in hinges seem to not lock in plus it won't catch the hinge pins please help Make sure hinges are in the closed position. Lift the door ABOVE the pins, push door/hinges into slots, then allow door to slip/slide down onto pins.
still not working hinges not conecting
Originally Posted by: mabzz4543 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) still not working hinges not conecting Can you see the horizontal pins on the lower edge inside the vertical opening the hinges slip into the body of the oven ? Can you see the slot in the hinge on the bottom edge which fits over the horizontal pin ? You will need to push the door against the body of the oven slightly in order to compress the door seal and allow the slot to reach back far enough over the pin before it drops into place. Otherwise, call a technician.
now that the door is on the oven door won't stay down when it is in the down or open position just keep wanting to come up have to hold it down in order to take something out. HELP
