FoleyPhoto
#1 Posted : Tuesday, February 17, 2009 9:35:39 AM(UTC)
FoleyPhoto
Hi, My dishwasher just went dead mid-cycle. It is filled with water, but did not get to the point where it pops open the soap. The panel does not light up at all. The house circuit breaker did not trip, and if I plug it into another outlet, it does not turn on either. All lights are off on the panel. Is there some sort of fuse or circuit breaker on the unit itself that I can reset? Or is there a part that I can buy and replace? Thanks. FoleyPhoto
jdappl07
#2 Posted : Tuesday, February 17, 2009 6:44:22 PM(UTC)
jdappl07
check the wirenuts at the bottom see if they are not burned or if they are on good. if good it will most likely be the control board or a wire came off
