2 Pages12>
matned
#1 Posted : Saturday, February 7, 2009 10:55:48 AM(UTC)
matned
Ge Spacemaker XL1800 Followed Troubleshooting flow chart to the INTERMITTENT PROBLEM-CALL-TAG-TEAM FOR RESOLUTION ?? My micro has not blown a fuse and will not cook. Help:confused:
#2 Posted : Saturday, February 7, 2009 7:56:27 PM(UTC)
Can you be more specific on what it does and what does not? What exactly did you test besides the fuse?
matned
#3 Posted : Sunday, February 8, 2009 4:01:05 AM(UTC)
matned
Gene I Followed the MWO Troubleshooting flow chart down to the clamp on ammeter to MWO's internal fuse lead and read > 8A. Chart tells me Magnetron & HV compts are good, then to call Tag Team for Resolution, due to intermittent problem ?? Re-Testing this morning and got smoke from HVT on Secondary ( Shut Down Imeeditly No Blown Fuses) All Functions on Key Board Work. will go to Cook cycle but no Heat. Bad HVC & HVD ?? Looking at replacing these, Can't get DVOM to Read differently on HVD, reads open when reversing leads, HVC reads Infinet ohms to Case & leads, No Burnt wires or shorts Found. Help ??:confused:
#4 Posted : Monday, February 9, 2009 11:17:26 AM(UTC)
Originally Posted by: matned Go to Quoted Post
...Re-Testing this morning and got smoke from HVT on Secondary ( Shut Down Imeeditly No Blown Fuses)... ...Can't get DVOM to Read differently on HVD, reads open when reversing leads...
HVT is bad and has to be replaced.
HVD most likely is good. You can run more reliable test as described in one of our previous posts: http://forum.appliancepartspros...19868-diode-testing.html
- The part number for the HVT is AP3206335
matned
#5 Posted : Monday, February 9, 2009 1:51:39 PM(UTC)
matned
Gene Thank-you for your Time. Matt
#6 Posted : Monday, February 9, 2009 3:16:07 PM(UTC)
matned
#7 Posted : Thursday, February 12, 2009 4:03:48 PM(UTC)
matned
Gene, Replaced HVT Still no heat Getting a loud hum now, Turn table , Light , Fan all working. Bad Mag :confused:
#8 Posted : Thursday, February 12, 2009 4:17:13 PM(UTC)
...You can run more reliable test as described in one of our previous posts: http://forum.appliancepartspros...19868-diode-testing.html...
Did you do this test? If you did and the diode is good then the culprit is the magnetron.
matned
#9 Posted : Friday, February 13, 2009 11:36:43 AM(UTC)
matned
Gene, Yes I tested the Diode with a 6 volt batterie and it functioned properly. Will replace the magnatron and let you know. Thank-you Matt
matned
#10 Posted : Saturday, February 28, 2009 4:33:43 AM(UTC)
matned
Gene replaced Magnatron and still no heat, decided to change CAP. Have heat run for about 50 sec then can hear oven load up , fan slows down. What should a wire to the mag read with a clamp-on amp. meter ?? Matt
Guest (6)
Lots of intermittent problems (Dishwasher Repair)
by djtoo 10/31/2013 2:33:05 PM(UTC)
GE Washer intermittent problems (Washer Repair)
by zjw2112 10/27/2013 4:00:28 AM(UTC)
Intermittent problem (Microwave Repair)
by teb02 12/7/2012 4:32:51 AM(UTC)
Dishwasher not filling completely, intermittent problem (Dishwasher Repair)
by walterw 3/17/2010 10:51:08 PM(UTC)
Intermittent Problem (Refrigerator & Freezer Repair)
by reed2112 12/26/2008 6:29:17 PM(UTC)
Intermittent Problem with Maytag Dishwasher (Dishwasher Repair)
by Firenut 3/15/2008 12:42:57 PM(UTC)
2 Pages12>
