BostonBobby
#1 Posted : Monday, December 5, 2011 6:21:54 AM(UTC)
BostonBobby
This side by side fridge - freezer is working fine. Defrost timer is working properly and fan is running strong. I just replaced the Air Diffuser, but no ar is coming into the fridge section. I tested the thermistors for continuity and they (freezer and fridge both) seemed to be good. ?when I replace the diffuser - should I feel air immediatley of will it take time? If not the diffuser - how to test the cold control?
richappy
#2 Posted : Tuesday, December 6, 2011 2:41:05 AM(UTC)
richappy
I would remove the freezer back panel and check for a fully frozen evaporator. If ok, open up the fridg door and check airflow from freezer, if ok, you have a blocked air return somewhere.
BostonBobby
#3 Posted : Tuesday, December 6, 2011 4:09:12 AM(UTC)
BostonBobby
I removed the back of the freezer wall and it is great. Where is the air return? The freezer is blowing cold very strong.
richappy
#4 Posted : Tuesday, December 6, 2011 5:12:06 AM(UTC)
richappy
Are you getting airflow when you open the fridg door?
BostonBobby
#5 Posted : Tuesday, December 6, 2011 5:33:43 PM(UTC)
BostonBobby
no. When I open the fridge there is no airflow
richappy
#6 Posted : Wednesday, December 7, 2011 12:18:01 AM(UTC)
richappy
Check the damper door in the diffuser, might be shut. If so, jam it open with a wad of duck tape, fridg should now get cold. Check the damper door thermostat behind the control panel, might be stuck. You can try a non-resdue contact cleaner available at Wall Mart to clean it.
