Is the thermal fuse on the blower housing or on the burner housing. Iam having trouble locating this. The dryer will not start or do anything. checked incoming power-good. Any ideas would be great.
Originally Posted by: feitian52  あの日, モンクレール ダウン、翔呉後に家の中で目をつぶる、突然あなたがマントラを唱え聞いた。Januaryこと、私はちょうどあなたの指先のタッチとしてではなく、救いのために、チューブのすべてを回す, モンクレール。その年、私はただ、あなたの暖かさに近い、聴衆のために、サジダ山ではない平身低頭。私は、山のターン水の転送塔に、あなただけで道を満たすために、死後の世界を修復しないこと, Moncler。 Thanks? Anyone else?
Good questions, I looked at the diagram and it looks like it would be on the heating element or duct work, should look something like this. WHIRLPOOL Sub La - 1053, part number: AP4055834Any thermostat or fuse should simple check closed with a ohm meter.
Originally Posted by: ApplianceJunk  Good questions, I looked at the diagram and it looks like it would be on the heating element or duct work, should look something like this. WHIRLPOOL Sub La - 1053, part number: AP4055834Any thermostat or fuse should simple check closed with a ohm meter. Thanks, how about the High LImit T stat . T - Stat Hi Limit Part Number: AP4056436 I cant seem to find a match to this on my dryer I found one that is similar, but it has 4 wires on it.
