fone_et
#1 Posted : Saturday, November 12, 2011 11:34:48 AM(UTC)
fone_et
Old Kenmore top bottom fridge. Compressor does not run until I slap my hand on the bottom of the top freezer. Gets cold then warms up again. Symptoms seem to point to a bad defrost timer. Can someone tell where the part is located on this model?
#2 Posted : Monday, November 14, 2011 1:16:02 PM(UTC)
Replacement parts for KENMORE 1068652781 | AppliancePartsPros.com
The defrost timer is in the control console at the top in the fresh food section.
Sounds more like a control thermostat problem than a defrost problem.
Next time it happens jiggle the temperature control back and forth a little if it fires up I would replace the thermostat.
Part number: AP3120051
fone_et
#3 Posted : Monday, November 14, 2011 2:51:32 PM(UTC)
fone_et
Thanks for the quick reply. Need further clarification. there are 2 controls. A cold control and a usage control. Is the the cold control that is the thermostat? Of course it is still running now and I can't try the moving the thermostat.
#4 Posted : Monday, November 14, 2011 6:03:18 PM(UTC)
If you go to the Sears parts site they will have parts breakdowns.
I do not know what they call the controls but it is the one on the left.
The other one opens/closes a damper which regulates the amount of cold air entering the fresh food compartment.
fone_et
#5 Posted : Tuesday, November 15, 2011 5:58:14 AM(UTC)
fone_et
The cold control is on the left so that for sure must be the thermostat. The fridge was warm again this morning. I turned the control a little to the left and right and the compressor started up. As soon as I figure out how to take the control panel off, get to that part, and see how to replace it I will order it. Thanks again
fone_et
#6 Posted : Thursday, November 17, 2011 7:34:36 AM(UTC)
fone_et
Ordered the thermostat and it arrived yesterday and I installed it. Took only one day to get it even with the standard shipping from Appliance pro. Installed it when I got it. It has been working for 24 hours so I assume it is fixed. Thanks a lot. I will not hesitate to use or recommend you guys in the future.
