engine207
#1 Posted: : Monday, January 19, 2009 8:31:25 AM(UTC)
engine207
I'm having a problem with my washer not being able to start up. When I press one of the wash cycles, the corresponding light indicator flashes, rather than remains solid. Once it's solid, I can normally press start and get the clothes going.
I checked the striker on the door and it is not damaged, so I'm assuming that it is the receiver that is mounted inside the cabinet and protrudes through a small 1" square hole.
I found a local parts shop that stocks it, but I am not sure how to open the unit to get at it. I see a few torx screws that seem to hold it in place from the inside, but I need help finding the way to access it.
Also, if anyone suspects that it is something other than that part, I'd appreciate your thoughts. Thanks...207
Drags1998
#2 Posted : Monday, January 19, 2009 1:48:31 PM(UTC)
Drags1998
The way to get to the door switch is to remove the OUTER boot clamp, There should be a spring at the bottom of the opening, carefully remove the wire and spring. The switch is just inside of the opening!!:)
midnitemill
#3 Posted : Monday, January 19, 2009 4:13:31 PM(UTC)
midnitemill
I had the same problem. I broke the locking clip inside small hole so I had
to pull the door lock. Don't know if this is my problem but I need to replace
it now. If you get any info please post and good luck
midnitemill
#4 Posted : Wednesday, January 21, 2009 6:17:06 PM(UTC)
midnitemill
Got new door switch installed ran diagnostic test all is good
Cycle still won't start found out my delicate cycle botton won't
turn on cycle.
richappy
#5 Posted : Thursday, January 22, 2009 1:32:30 AM(UTC)
richappy
If you have a meter, you could pull off the top cover and check the door switch at the control board.
Kenmore HE3 won't start, with no codes? (Washer Repair)
by ZEUS1981 2/4/2010 5:00:39 PM(UTC)
