3 Pages123>
wotan2525
#1 Posted : Tuesday, January 20, 2009 6:51:51 PM(UTC)
wotan2525
Dishwasher fills, does not wash, and then drains.... where to start?
#2 Posted : Wednesday, January 21, 2009 2:59:12 AM(UTC)
Here is your parts
Model KUDI01ILBL3
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%208537797.pdf
Use the tech sheet and see if you can troubleshoot the unit.
If unit's timing is correct and it just not washing, then check to see if the wash motor is getting voltage when it should.
Could be something as simple as a broken wire where the cables go from the door to under the cabinet.
wotan2525
#3 Posted : Wednesday, January 21, 2009 5:26:23 AM(UTC)
wotan2525
So.... I put it in diagnostic mode and then how do I "check the timing?" Sorry... totally new to this!
#4 Posted : Wednesday, January 21, 2009 7:16:07 AM(UTC)
You are not really checking the timing you just want to see if you can get the wash motor to run.
Just go slowly through the tech sheet to see if anything just seems strange.
wotan2525
#5 Posted : Wednesday, January 21, 2009 7:19:17 AM(UTC)
wotan2525
I put it in diagnostic mode and stepped through the cycles.... it fills just fine... when it enters the "wash" cycle the motor buzzes but never sprays any water... then it hits the drain cycle and drains just fine. Is the motor bad?
#6 Posted : Wednesday, January 21, 2009 7:47:45 AM(UTC)
Could be you have something jammed in the chopper or impeller.
You will have to open it up to check this
I will look to see if I can find you some decent instructions
wotan2525
#7 Posted : Wednesday, January 21, 2009 7:50:09 AM(UTC)
wotan2525
I think I can do this.... I took it all apart to clean it once about a year ago... this shouldn't be too tough. Thanks!
If I don't find a jam/obstruction.... what's the next step?
#8 Posted : Wednesday, January 21, 2009 8:04:56 AM(UTC)
This may help if you get stuck
<title>Replacing Kitchenaid and Whirlpool Tall Tub Dishwasher Pumps
And this just for your info
<title>Kitchenaid Dishwasher making Noise
If the motor chopper/impeller turns easily by hand then it is probably either the motor itself or the capacitor
wotan2525
#9 Posted : Wednesday, January 21, 2009 7:24:23 PM(UTC)
wotan2525
I've got the entire sump assem. out now.... how do I troubleshoot whether it's the cap or the motor itself?
#10 Posted : Thursday, January 22, 2009 3:11:33 AM(UTC)
Do you have an ohm meter?
If yes, what type digital or analogue?
A meter will let you do some basic checking of the motor and the capacitor.
It will do a basic check and show some faults but will not do an absolute check.
I am not quite sure how to explain what I mean, as an example measuring the capacitor. It will check that the capacitor is not a dead short or that it is not an open and that it can take a charge. It will not check it at the operating voltage levels so if the capacitor is breaking down at a higher voltage, it cannot check this. Special equipment is required to do an absolute test.
Hope the above makes sense.
You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Guest (7)
3 Pages123>
