4 Pages123>»
charleyk
#1 Posted : Sunday, January 18, 2009 12:58:48 PM(UTC)
charleyk
The machine does not move to wash cycle and keeps filling unless I move the dial manually. From reading other threads, my suspicion is the pressure control hose but I am unable to find how to get to it on the machine.
Does to top lift up or do I need to go through the back?
Thanks for any help.
charleyk
#2 Posted : Sunday, January 18, 2009 3:21:40 PM(UTC)
charleyk
I'm finding that this happens intermittently. We ran a few more cycles and it worked sometimes and sometimes just kept filling. Any help would be appreciated.
kayakcrzy
#3 Posted : Monday, January 19, 2009 4:09:23 AM(UTC)
kayakcrzy
Yes, it does sound like the water level switch. First unplug the washer, and by the picture it looks like you have to pop the end caps off the right and left side of the control panel, and then, behind each one is a phillips head screw, holding down the front. Remove both of them, and then flip up the control panel, and you can get to the water level switch from there. Tom
charleyk
#4 Posted : Monday, January 19, 2009 4:48:38 AM(UTC)
charleyk
How do I identify the switch and how do I determine if this is in fact the problem?
kayakcrzy
#5 Posted : Monday, January 19, 2009 5:00:16 AM(UTC)
kayakcrzy
The switch is the one that you turn to set the load water level on small, medium, and large. If you pull up the control panel, like I said, and locate the switch, there will be a clear plastic hose, attached to it. Pull the hose off, and blow through it. If you can, then replace the switch. If not, where the other end of the hose goes, which is on the right side of the drum, close to the back, it would be clogged there, sending a false message to the water level switch. Tom
charleyk
#6 Posted : Monday, January 19, 2009 7:08:02 AM(UTC)
charleyk
Thanks kayakcrzy. I'm going to try it later this evening and will get back to you. It sounds pretty easy to do.
charleyk
#7 Posted : Monday, January 19, 2009 7:17:51 AM(UTC)
charleyk
One other thing kayakcrzy. If the hose happens to be clogged, will I be able to get the the other end of the hose next to the drum, from the panel area or will I need to take anything else off? Thanks again.
kayakcrzy
#8 Posted : Monday, January 19, 2009 1:06:50 PM(UTC)
kayakcrzy
Actually if you pull the washer away from the wall, and make sure it is unpluged, and lean it back up against the wall, and lay down on the floor, and get to it from there. Tom
charleyk
#9 Posted : Monday, January 19, 2009 2:46:09 PM(UTC)
charleyk
The hose does not seem to be clogged. I was able to blow in it and could hear air going straight through. Does this mean that the only thing it can be is the switch or could the hose be broken somewhere between the switch and the drum? It did work intermittently so I'm thinking if the hose was busted, it would never work correctly. What do you think?
kayakcrzy
#10 Posted : Monday, January 19, 2009 4:16:51 PM(UTC)
kayakcrzy
Most of the times it is the water level switch. You could pull the hose from the water level switch and the tub, and hold your finger on one end, to close it off, and blow through it. If you cannot blow through it with your finger clogging up the other end, I would replace the water level switch. Tom
4 Pages123>»
