4 Pages<1234>
charleyk
#11 Posted : Monday, January 19, 2009 5:15:07 PM(UTC)
charleyk
Any idea how much the switch costs? Do you know if its expensive?
kayakcrzy
#12 Posted : Tuesday, January 20, 2009 4:01:01 AM(UTC)
kayakcrzy
It goes for about 20 to 25 bucks. Tom ApplianceEducator.com
charleyk
#13 Posted : Sunday, January 25, 2009 12:01:20 PM(UTC)
charleyk
Oh well. I replaced the switch and it looked OK for a few days. Now it happened again. I checked the hose from the switch to the basin and its completely clear. I even blew compressed air through to see if it was a little clogged.
Any ideas on whar to do now. This is getting frustrating.
kayakcrzy
#14 Posted : Sunday, January 25, 2009 12:49:59 PM(UTC)
kayakcrzy
Charlie, pull your drain hose out of the drain, and tell me how far it went in. Tom ApplianceEducator.com
charleyk
#15 Posted : Sunday, January 25, 2009 2:53:00 PM(UTC)
charleyk
Do you mean the hard rubber darin hose that goes into the pipe on the wall for draining?
charleyk
#16 Posted : Sunday, January 25, 2009 3:09:33 PM(UTC)
charleyk
If thats the hose your talking about, it's about 3 inches in. maybe about halfway between the end and the big bend.
Is it possible that something is wrong between where the pressure hose fits onto the drum and the drum? I blew air in throught the hose and I could see it come out in the drum, but doesnt the water level switch work on pressure coming back through that tube? So, if there wasn't enough (or any) pressure coming back, the switch wouldn't turn off the flow of water? I pulled the hose off while the tun was full of water and there seemed to be no pressure.
Or maybe I'm just getting frustrated and trying to think of anything.
charleyk
#17 Posted : Sunday, January 25, 2009 6:02:59 PM(UTC)
charleyk
I think I know what you are thinking on this so I pulled the drain house out so that it's just in the drain for some airflow. Still the same problem. Could the timer do this?
kayakcrzy
#18 Posted : Monday, January 26, 2009 4:38:48 AM(UTC)
kayakcrzy
Yes it can. It is hard for me to pin this one down from here. But it is possible it could be the timer. Tom ApplianceEducator.com
charleyk
#19 Posted : Monday, January 26, 2009 4:48:46 AM(UTC)
charleyk
I'm thinking it's time to get another machine. The timer has got to be pretty expensive. Are there any simple tests to check it?
abbie
#20 Posted : Monday, January 26, 2009 6:29:48 AM(UTC)
abbie
CHARLEYK...The next time it overfills,how do you stop the water?? Do you shut off the [cold or hot]water... tap or by pulling the power plug or shutting off the timer [knob]..??If you stop it by the timer or plug it,s in the timer.. If it the water tap it,s the mixing valve[cold..hot water valve on the washer]....g luk
4 Pages<1234>
