2 Pages12>
blackcobra427
#1 Posted : 13 years ago
blackcobra427
my dryer wont turn on, it worked yesterday, but now wont turn on, past two to three weeks it would turn on and work but then shut off, when i turned the timer dial it would work again, but now nothing, i'm wondering if the timer is bad? any help would be awsome
thanks
magician59
#2 Posted : 13 years ago
magician59
To troubleshoot it, we need to test a few of the components (This helps prevent unnecessary replacement of parts that are good). Do you have a meter? Can you do a little electrical testing?
blackcobra427
#3 Posted : 13 years ago
blackcobra427
thanks
yes i do have a meter, and yes i can test, if i know what i'm looking for?
blackcobra427
#4 Posted : 13 years ago
blackcobra427
yes i can test if you let me know what to test
magician59
#5 Posted : 13 years ago
magician59
Start at the power source. You're looking for 240VAC (or pretty close to it) at the outlet. Further test to make sure there is 120VAC from each of the hot legs in the outlet to the ground (or neutral, if you have a 4-conductor receptacle).
After confirming the correct power at the outlet, try the dryer in all of the drying cycles. If you get action in one cycle, and not onothr, it's a fair bet that the trouble is with the timer.
Let us know what you find.
blackcobra427
#6 Posted : 13 years ago
blackcobra427
i have power everywhere and it doesn't work at all, is there a way i can check the timer or on switch or button?
magician59
#7 Posted : 13 years ago
magician59
Check the door switch. You can also check the start switch. They rarely fail, but since you're already into the console, it can't hurt to check it.
blackcobra427
#8 Posted : 13 years ago
blackcobra427
i have power to the timer switch, and the start button the start button is working, so do you think its the timer switch? like i said there is power to the timer but i don't know check the out going of the timer
magician59
#9 Posted : 13 years ago
magician59
Without a schematic, I also don't know which timer contacts to test. Did you test the door switch?
blackcobra427
#10 Posted : 13 years ago
blackcobra427
yes it works, i checked the complete circuit on the switch
LG Dryer wont turn on (Dryer Repair)
by stz2 4 years ago
Kenmore Dryer Wont Turn On (Dryer Repair)
by tmurphy12 7 years ago
Dryer wont turn on. Nothing at all (Dryer Repair)
by jim5775 12 years ago
Dryer wont turn on, bulb stays on when door closed (Dryer Repair)
by mazw 13 years ago
Dryer wont turn on, bulb stays lit when door closed (Dryer Repair)
by sweetness 13 years ago
admiral dryer wont turn on (Dryer Repair)
by tammy27 13 years ago
by G.A.Russell 13 years ago
Roper Dryer wont turn on (Dryer Repair)
by edwardsnl 14 years ago
by snooki 14 years ago
by ritadi 15 years ago
by carri0321 15 years ago
lady kenmore ultra fabric care electric dryer wont turn on (Dryer Repair)
by John414 15 years ago
Frigidaire dryer wont turn on (Dryer Repair)
by gamermom79 15 years ago
by jake@studioyoshida.com 15 years ago
2 Pages12>
