2 Pages12>
blackcobra427
#1 Posted : Wednesday, November 2, 2011 9:31:12 AM(UTC)
blackcobra427
my dryer wont turn on, it worked yesterday, but now wont turn on, past two to three weeks it would turn on and work but then shut off, when i turned the timer dial it would work again, but now nothing, i'm wondering if the timer is bad? any help would be awsome
thanks
magician59
#2 Posted : Wednesday, November 2, 2011 9:33:45 AM(UTC)
magician59
To troubleshoot it, we need to test a few of the components (This helps prevent unnecessary replacement of parts that are good). Do you have a meter? Can you do a little electrical testing?
blackcobra427
#3 Posted : Wednesday, November 2, 2011 9:36:31 AM(UTC)
blackcobra427
thanks
yes i do have a meter, and yes i can test, if i know what i'm looking for?
blackcobra427
#4 Posted : Wednesday, November 2, 2011 9:42:29 AM(UTC)
blackcobra427
yes i can test if you let me know what to test
magician59
#5 Posted : Wednesday, November 2, 2011 9:49:30 AM(UTC)
magician59
Start at the power source. You're looking for 240VAC (or pretty close to it) at the outlet. Further test to make sure there is 120VAC from each of the hot legs in the outlet to the ground (or neutral, if you have a 4-conductor receptacle).
After confirming the correct power at the outlet, try the dryer in all of the drying cycles. If you get action in one cycle, and not onothr, it's a fair bet that the trouble is with the timer.
Let us know what you find.
blackcobra427
#6 Posted : Wednesday, November 2, 2011 10:00:12 AM(UTC)
blackcobra427
i have power everywhere and it doesn't work at all, is there a way i can check the timer or on switch or button?
magician59
#7 Posted : Wednesday, November 2, 2011 10:06:11 AM(UTC)
magician59
Check the door switch. You can also check the start switch. They rarely fail, but since you're already into the console, it can't hurt to check it.
blackcobra427
#8 Posted : Wednesday, November 2, 2011 10:35:01 AM(UTC)
blackcobra427
i have power to the timer switch, and the start button the start button is working, so do you think its the timer switch? like i said there is power to the timer but i don't know check the out going of the timer
magician59
#9 Posted : Wednesday, November 2, 2011 11:24:19 AM(UTC)
magician59
Without a schematic, I also don't know which timer contacts to test. Did you test the door switch?
blackcobra427
#10 Posted : Wednesday, November 2, 2011 11:41:40 AM(UTC)
blackcobra427
yes it works, i checked the complete circuit on the switch
Guest (6)
LG Dryer wont turn on (Dryer Repair)
by stz2 7/28/2021 2:09:54 AM(UTC)
Kenmore Dryer Wont Turn On (Dryer Repair)
by tmurphy12 11/11/2017 5:37:21 PM(UTC)
Dryer wont turn on. Nothing at all (Dryer Repair)
by jim5775 2/7/2013 1:31:10 PM(UTC)
Dryer wont turn on, bulb stays on when door closed (Dryer Repair)
by mazw 7/24/2012 4:21:01 PM(UTC)
Dryer wont turn on, bulb stays lit when door closed (Dryer Repair)
by mazw 7/24/2012 4:13:34 PM(UTC)
by sweetness 6/21/2012 12:24:11 PM(UTC)
admiral dryer wont turn on (Dryer Repair)
by tammy27 6/12/2012 1:08:36 PM(UTC)
by G.A.Russell 2/12/2012 12:42:26 PM(UTC)
Roper Dryer wont turn on (Dryer Repair)
by edwardsnl 1/15/2011 12:37:58 PM(UTC)
by snooki 12/2/2010 5:45:01 PM(UTC)
by ritadi 7/4/2010 9:30:53 AM(UTC)
by carri0321 3/29/2010 1:34:12 PM(UTC)
lady kenmore ultra fabric care electric dryer wont turn on (Dryer Repair)
by John414 3/6/2010 7:19:25 AM(UTC)
Frigidaire dryer wont turn on (Dryer Repair)
by gamermom79 1/13/2010 11:15:41 AM(UTC)
by jake@studioyoshida.com 11/9/2009 6:28:16 AM(UTC)
2 Pages12>
