I have a 6 year old Jenn-Air side-by-side refridge model JCD2389DTB. It works great for a while then goes warm inside for a long period of time (food goes bad in refridge and frozen stuff thaws). When I unplug it and let it sit empty with doors open for at least a day then later power it back up it works fine again for a while ... for maybe a year, maybe a month, but lately a week or so and decreasing. Any one have any clues? f.licata@comcast.net
When the refrigerator starts acting up do you hear it making a clicking noise?
Do you notice any frost build up on the inside back freezer wall when it stops cooling?
No noises noted. I didn't look but there may be some frost because the floor gets a puddle of water on it after I unplug it.
Watch the back wall for frost build-up. You should never see any. If you do then you have a defrost problem.
Thanks alot for your help. I was just reading a thread on this very topic over at applianceguru.com and it seems that I have a bad adaptive defrost control board, which I understand is very common for the brand "Junk"-Air.
Yeah, they have some trouble with them. Over all Jenn-Air is good stuff.
Thanks,
I just removed the adaptive defrost control board and the cheezy 10amp contacts on the compressor relay are stuck closed. That's why it was running 24/7/365 and also why my electric bill skyrocketed. The board is made by Siebe Appliance Controls, and the board revision is from 1996.
Glad you found the trouble. Thanks for the update.
Originally Posted by: ApplianceJunk When the refrigerator starts acting up do you hear it making a clicking noise?
Do you notice any frost build up on the inside back freezer wall when it stops cooling? Hello, I have this problem with my fridge, frost in freezer and every so often a clicking on the top of the refridgerator. had defrost board replaced a few years back,could it be bad again thanks
