Originally Posted by: rkelly51 The temp switch seems to be working ok. What voltage should be going to the valve? Is there a wiring diagram for the timer?
Kelly,
Voltage to the fill valve, will be 120 VAC (line voltage).
Orange/Black to White Green is the hot water valve, and will have 120 VAC when hot or warm fill is selected.
Blue/Black to White/ Green is the cold water valve and will have 120 VAC when cold or warm fill is selected.
We don't have a PDF file we can transmit to you, but, when you lower the control panel to access the timer, you should find it inside the control console.
( to remove the console, remove the two inner phillips head screws in the front corners of the console top trim, and pull or lean the top towards you, and the bottom will release from the housing).
To test the timer circuits in the fill increment :
Unplug the power cord, set the timer dial to the start of the regular wash cycle and pull the timer dial out.
(you may want to remove the timer, some of the terminals will be on the inside portion of the timer, and may be hard to access).
At the timer, with the wires removed from the terminals, you want to check for a "closed" circuit between :
Terminal 7t(wht/blu) and 7a (Purple).
Terminal 7t(wht/blu) and 15 (brown).
Terminal 21(blue) and 32(red).
Terminal 32(red) and L2(wht/green).
Terminal 22(yellow) and 9(white).
If all these timer circuits check OK, the timer is not at fault.
Check the water level switch:
Disconnect the air dome hose(1/4 tube) from the switch,
Disconnect the gray (terminal #7) from the switch.
Check for a "closed" circuit between terminal 7(gray) and 15(brown).
Check for an "open" circuit between terminal 7 and 16(yellow/black).
Also while its disconnected, blow into the 1/4 tube, to clear any possible clogs or debris, that may have accumulated over the years.
Normally, a water valve solenoid ranges between 500 and 1000 Ω s resistance, but thats not always a good indicator. If everything checks OK, replace the fill valve.
