yupper18
#1 Posted : 17 years ago
yupper18
The dryer will not stop running, I replaced the timer but the same problem is occuring? Help John
#2 Posted : 17 years ago
Hi John
Did it start without pushing the start button?
How does it dry?
yupper18
#3 Posted : 17 years ago
yupper18
No it will not run without pushing the start button. It dry's the cloth's fine but once the cycle is finished it will not shut off.
#4 Posted : 17 years ago
Did the timer move to the off position by itself or it skipped the off position and kept running? Did the timer move at all?
yupper18
#5 Posted : 17 years ago
yupper18
I'am wrong when you close the dryer door it will start up on it's own, also the timer does function properly. John
#6 Posted : 17 years ago
In such case no doubt the problem is the shorted start switch which has to be replaced.
- The part number for the start switch AP2975301
Good luck.
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 about a year ago
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius about a year ago
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 2 years ago
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 2 years ago
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 2 years ago
Kenmore dryer issue when heat is on (Dryer Repair)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 2 years ago
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 3 years ago
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
kenmore dryer wiring (General Talk)
by epyveras 3 years ago
KENMORE DRYER WIRING 796.813 (Dryer Repair)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 3 years ago
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 4 years ago
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 4 years ago
