The dryer will not stop running, I replaced the timer but the same problem is occuring? Help John
Hi John
Did it start without pushing the start button? How does it dry?
No it will not run without pushing the start button. It dry's the cloth's fine but once the cycle is finished it will not shut off.
Did the timer move to the off position by itself or it skipped the off position and kept running? Did the timer move at all?
I'am wrong when you close the dryer door it will start up on it's own, also the timer does function properly. John
In such case no doubt the problem is the shorted start switch which has to be replaced. - The part number for the start switch AP2975301 Good luck. Gene.
