2 Pages<12
#11 Posted : 16 years ago
Would the inner tub spin if you'll help with your hands?
Ryan Dingmann
#12 Posted : 16 years ago
Ryan Dingmann
No, when I try to help the washer spin with my hands, the machine still does not spin (after closing the lid switch of course).
My washer is sounding most like this description you previously wrote in this thread -
"If does agitate and drain but does not spin at all then it could be a bad drive block, a bad clutch or a bad transmission (the transmission should be under the limited manufacturer warranty)."
What do you suggest to try first?
#13 Posted : 16 years ago
Hi Ryan,
Sorry for the delay. I would recommend to check the clutch first. In order to access the clutch you have to remove the transmission. You can find the complete disassembly instructions in the Service manual.
Here are the break down diagrams for the Roper washer Model RAX7245KQ0
joejoe77
#14 Posted : 13 years ago
joejoe77
roper 8525148
judas.. sock in pump!
was gonna work on kitchen lights .. so turned off fuses...opp i turned off washer/dryer.
so turned it back on..went to turn on dryer/washer
found washer drained and spinned .. hmm..
was able to turn dial and she started fillin so walked away .. oh well i thought.
came back she was full.
started playing with dial.
she would only humm... and not spin or agitatate or drain.. thought maybe a dial gaget prob.
other mentioned may be a lid fuse or connector thingy
judas!
even when i put my hand in .. I could not spin the big thingy.
then i started thinking motor ceased...
I just kept playing with dial .. filling/ drainin with bucket .. and she kicked in for a sec.
then the spinny thing inside freely moved.
tried to carry on.. and boom .. still hum.. moved an inch and centre thing locked again.
ahhhh
so there I go takin off the back .. breakin plasit clips etc.
All I had to do was tip machine on its back
and a hose went in and another hose went out of this white disk.
Unclipped white disk
pulled off hoses
looked inside disk..and there was a little baby sock wrapper around a plastic flywheel inside beige circlar thingy right on bottom of washer.
puller er out. she work perfect.
cept for all the plastic stuff I ruined pulling the back off it..
ahhh..one of those middle / back plastic things held the water filler thingy..
roper 8525148
judas!
ahhhh
pulled off hoses
roper 8525148
judas!
ahhhh
pulled off hoses
roper 8525148
judas!
ahhhh
pulled off hoses
judas!
ahhhh
pulled off hoses
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 12 months ago
Samsung washer won't spin (Washer Repair)
by Guest 3 years ago
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 3 years ago
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4 years ago
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 5 years ago
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 6 years ago
Washer won't spin out. (Washer Repair)
by DJChad818 7 years ago
Washer won't spin (Washer Repair)
by Fingers123 7 years ago
Washer Won't Spin (Washer Repair)
by je00409 7 years ago
Washer won't spin or agitate (Washer Repair)
by dhughes 8 years ago
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 8 years ago
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 8 years ago
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 8 years ago
maytag washer won't spin fast (Washer Repair)
by benp1 8 years ago
by lmhansgen 9 years ago
2 Pages<12
