AppliancePartsPros.com
Appliance Repair Help
Washer Repair
tried replacing door latch electronic control board
Nothing on the display responds except the control lock button dings when pushed. I ordered a new electronic control board and latch. The new control board showed errors on the latch and drain pump. I changed out the door switch and checked out the pump but nothing changed. Since the original control board and the new one did not respond the same, I ordered another control board. It responded the same as the original. With the front panel so unresponsive it is hard to diagnose anything. I have gone through the tech sheets and tried everything i can think of. Is the front control panel ,part # AP4538150 the next thing to try? Thanks
Originally Posted by: sparks87144 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Nothing on the display responds except the control lock button dings when pushed. I ordered a new electronic control board and latch. The new control board showed errors on the latch and drain pump. I changed out the door switch and checked out the pump but nothing changed. Since the original control board and the new one did not respond the same, I ordered another control board. It responded the same as the original. With the front panel so unresponsive it is hard to diagnose anything. I have gone through the tech sheets and tried everything i can think of. Is the front control panel ,part # AP4538150 the next thing to try? Thanks Sparks, Yes, the user interface control board is the next move. Part number: AP4538150
Also check the harness between the UIC and The CCU(centeral control unit) for tiht proper connections. :) :) :)
Washer Repair
