stu22180
#1 Posted : Saturday, October 1, 2011 5:08:25 PM(UTC)
stu22180
Hello,
My Kenmore Dryer Model 110.82824102 no heat. I have tested the below items.
Heater coil "Good"
Thermal cut-off "Good"
High limit thermostat "Good"
Thermal Fuse "Good"
I trace the problem back to the Control Board heater relay. The relay dose not turn on when the Dryer is running. Is their other testing to Control Board I can do?
Thanks Stu
#2 Posted : Sunday, October 2, 2011 2:57:03 AM(UTC)
You have been a member since:: 2/29/2008(UTC)
Replacement parts for KENMORE 11082824102 | AppliancePartsPros.com
Check the thermistor.
How do you know the heater relay is not closing?
Have you checked the power to the unit?
The heating coil requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
File Attachment(s):
82824102.pdf (418kb) downloaded 12 time(s).
stu22180
#3 Posted : Thursday, October 13, 2011 6:19:16 AM(UTC)
stu22180
This is a note "What fixed the problem"
I got a new controller board PN:8557308 and pluged it in. Now the Dryer works.
Thanks for all your help.
Stu
control board testing (Dishwasher Repair)
by bnolder 12/3/2011 6:26:04 AM(UTC)
