kyle000
#1 Posted : Monday, September 19, 2011 11:50:24 PM(UTC)
kyle000
microwave buzzing only when carosel is turning...stops buzzing when turntable inactive. no lightning/arching present. plz help, ty
Joe / APP Team
#2 Posted : Tuesday, September 20, 2011 5:58:50 AM(UTC)
Joe / APP Team
Kyle,
Have you isolated the buzzing noise ?
If the noise is near the center, bottom, of the unit, That would indicate a bad turntable motor,
Part number: AP2024962
If the noise is from the upper area, or the control panel, You would have a chattering relay or loose connection on the PCB.
Part number: AP3192717
The turntable motor is the more likely issue, it's a low voltage motor (21 VAC) and loose connections have a large effect on the motor windings.
Thanks,
kyle000
#3 Posted : Tuesday, September 20, 2011 5:05:07 PM(UTC)
kyle000
yes joe, the noise is coming from the bottom of the unit. u mentioned loose wires. when i get to the motor should i check to see if a loose connection may be the problem... or by now its too late and damage is done?
thx for ur help
Joe / APP Team
#4 Posted : Thursday, September 22, 2011 5:15:44 AM(UTC)
Joe / APP Team
thx for ur help
Kyle,
Order and install the new turntable motor(see previous post), and make sure the connections are tight on the new motor assembly.
