bratsinc4
#1 Posted : Wednesday, February 4, 2009 6:05:06 PM(UTC)
bratsinc4
My whirlpool dryer would not start so I read some of the tips on some of the other postings and saw that it is probably the thermal fuse, but it said that if you replace it then you should probably replace the operating thermostat at the same time. My question is that I have 3 different thermostats on my dryer. 1) thermostat, internal bias 2) thermal cut-off for heating element and 3) thermostat, fixed Which one is considered the operating thermostat? :confused: Thanks
kayakcrzy
#2 Posted : Thursday, February 5, 2009 1:35:42 AM(UTC)
kayakcrzy
You are right about the thermal fuse, and the thermostat being changed at the same time, but that is not your problem. In the back the is another thermal fuse. It is white in color, and about an inch and a half long, by a half inch wide, and has 2 wires coming to it, and it is held in by 1 screw. That is most likely the problem. If not, it would be a door switch, or a bad breaker. Tom ApplianceEducator.com
bratsinc4
#3 Posted : Friday, February 6, 2009 5:52:17 PM(UTC)
bratsinc4
Tom
Thanks so much for your help :) I ordered the thermal fuse, replaced it and now my dryer is working like a charm! I live in the country and if I would have had to have a repair guy out it would have cost me a fortune, but with your help I was able to fix it myself! Thanks again!
Stacey
kayakcrzy
#4 Posted : Saturday, February 7, 2009 4:04:06 AM(UTC)
kayakcrzy
Thanks you so much for letting me know. Good Job!!! Glad to have saved you the money. Tom ApplianceEducator.com
pshisbey
#5 Posted : Thursday, September 8, 2011 5:21:22 PM(UTC)
pshisbey
My whirlpool drier wouldn't start either. Replaced the thermal fuse ($25 later) and it runs as good as new. Very easy to replace! Thank you Tom and Sacey!
I used the following links
http://www.whirlpool.com
Appliance Parts from WhirlpoolPartsOnline.com
Phil
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Whirlpool Dryer will not start, have power "sensing light is on" Replaced both thermi (Dryer Repair)
by joanu 11/21/2013 6:32:09 AM(UTC)
Whirlpool dryer will not start (Dryer Repair)
by vaughn quern 11/26/2012 9:52:02 AM(UTC)
by vaughn quern 11/26/2012 9:44:09 AM(UTC)
whirlpool dryer will not start (Dryer Repair)
by mikeshard 3/29/2012 8:49:17 PM(UTC)
Whirlpool dryer will not start. (Dryer Repair)
by c33341 3/11/2011 9:47:28 AM(UTC)
by Newglide 1/12/2011 6:54:14 PM(UTC)
by dafense 2/10/2010 6:13:16 PM(UTC)
by mbryans 1/7/2010 12:31:19 PM(UTC)
by rsqmedic8 7/26/2009 7:43:08 AM(UTC)
