madmanracing11
#1 Posted : Thursday, November 1, 2007 7:25:36 PM(UTC)
madmanracing11
I have this washer machine that seems to work in all cycles.....except for the spinning of the drum. The motor runs. The timer seems to advance. The water fills and drains. Any ideas for me? I'd like to diagnose the problem and fix it if possible.:) :D
Laurence23
#2 Posted : Thursday, November 1, 2007 8:56:25 PM(UTC)
Laurence23
read my thread see if that helps you
richappy
#3 Posted : Friday, November 2, 2007 3:35:36 AM(UTC)
richappy
Remove panel screws and tilt back, now remove outer cover of washer,remove pump and motor.
Turn tranny coupler clockwise till drum turns. If very hard to turn you either have dragging brake shoes, or something stuck in the tub.
If easy to turn, you have a worn out clutch or bad spin basket drive block.
Please post results.
peterb
#4 Posted : Wednesday, November 21, 2007 6:00:50 AM(UTC)
peterb
How do you remove the top of a Kenmore washer?:confused:
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
