aagra
#1 Posted : Tuesday, August 16, 2011 8:43:45 AM(UTC)
aagra
The "Time Cook" button on my microwave doesn't work anymore, all of the other buttons work and we're still able to use the microwave by using the "30 second" button.
I was thinking of fixing the problem by replacing the Control Panel Assembly, part# WB07X10626.
I found the part (#120) on the GE parts diagram: https://genet.geappliances.com/I...0048500/00048520.p01.pdf
Could anyone give me their opinion on whether this would fix my issue?
Is it as simple as I think it is?
1. Remove the griddle,
2. unscrew the panel screw, slide it up and out,
3. unplug it
4. swap it out with the new control panel
I don't want to do anything stupid.
aagra
#2 Posted : Tuesday, August 16, 2011 9:29:25 AM(UTC)
aagra
I found this part, the Key Panel,
GE WB27X10677 Key Panel, AP3203231 | AppliancePartsPros.com
is this more precisely what I need to replace instead?
