garry carpenter
#1 Posted : Friday, May 13, 2011 1:18:24 PM(UTC)
garry carpenter
been out of the country for a few months microwave was un plugged from wall, on reconnecting it only says F3 and the touch pad wont change anything.Any advice would be appreciated.
Regards Garry
#2 Posted : Friday, May 13, 2011 4:21:39 PM(UTC)
Garry,
The "F3" error code means "Shorted key panel". The correction is to replace the membrane switch (#15 on the diagram).
- The membrane switch Part number: AP3191565
blagasse24
#3 Posted : Sunday, August 14, 2011 12:49:30 PM(UTC)
blagasse24
I'm having a similar issue with JVM1870SF001; I was able to unplug & re-plug inn the microwave and doing that several times over the course of a month got me by. Now that won't work either. I want to make sure I'm ordering the right part. Do I need just a keypad or the whole control panel? If just a keypad, what is the part number? My model has a black keypad currently.
Thank you!
Garry,
#4 Posted : Sunday, August 14, 2011 4:43:31 PM(UTC)
According to the model number you posted you have to order the complete control panel.
- The control panel Part number: AP3418746
blagasse24
#5 Posted : Sunday, August 14, 2011 5:39:39 PM(UTC)
blagasse24
That's what I thought but glad to hear. Thank you for your quick response. I'll check back in on how the new part works.
#6 Posted : Sunday, August 14, 2011 5:43:12 PM(UTC)
You are welcome. Good luck.
blagasse24
#7 Posted : Sunday, August 21, 2011 6:24:08 AM(UTC)
blagasse24
Just wanted to follow up that the control panel did the trick. Thanks! One thing for others to note that the ribbon from the control panel needs to be coerced into the proper port on the smartboard. The first time I tried I didn't want to push it too hard and it wasn't in far enough. So when I turned the power on, I got to the point where I needed to set the clock, but none of the touchpad keys worked. I unscrewed the control panel and just worked on pushing the ribbon in all the way and that did the trick. Microwave's as good as new now. Thanks again!
#8 Posted : Tuesday, August 23, 2011 3:18:39 PM(UTC)
You are welcome. Thank you for the feedback.
Guest (5)
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
GE profile smart (Washer Repair)
by Guest 4/15/2024 4:35:38 AM(UTC)
Ref - GE Profile Range Model No. PS950EF3ES (Oven Repair (including Ranges and Cooktops))
by JimBAgde 4/6/2024 11:11:04 AM(UTC)
GE Profile Freezer Wildly Varying Temps (Refrigerator & Freezer Repair)
by Guest 3/26/2024 3:54:40 PM(UTC)
Water dispenser not working GE Profile PSHs6TGXBDS (Refrigerator & Freezer Repair)
by klkaylor78 2/3/2024 11:07:08 AM(UTC)
GE Profile PSC23SGPA (Refrigerator & Freezer Repair)
by dwhit 10/3/2023 10:25:11 AM(UTC)
Whirr whirr whirring sound from my GE Profile PFE28RSHHSS refrigerator (Refrigerator & Freezer Repair)
by Guest 4/29/2023 7:48:19 AM(UTC)
GE Profile refrigerator PY model - chime not working (Refrigerator & Freezer Repair)
by Guest 2/7/2023 8:07:10 AM(UTC)
GE Profile erratic temperatures (Refrigerator & Freezer Repair)
by david2u 2/4/2023 9:51:52 AM(UTC)
Buy (300 Pieces) New GE Profile - Opal 2.0 38-lb. Ice Maker Dispenser $134,700 (General Talk)
Belarus eikohajime30 1/4/2023 11:05:58 PM(UTC)
Dishwasher Repair for GE profile (Dishwasher Repair)
by Guest 12/10/2022 11:15:25 AM(UTC)
GE Profile Range Timer Button Not Working (Oven Repair (including Ranges and Cooktops))
by Bush444 11/23/2022 10:11:35 AM(UTC)
Dishwasher GE PROFILE MODEL PDT825SSJSS (Dishwasher Repair)
by apeconsulting 9/13/2022 9:02:22 PM(UTC)
GE Profile ice maker intermittently worked, now completely dead (Refrigerator & Freezer Repair)
by wolfpack95 8/29/2022 7:27:03 AM(UTC)
