I have a defrost problem (ice build up on evaporator over a few days). The refer never will go into defrost mode. I can jumper the Line and Defrost connector on the main control board and the defrost heater turns on. I changed the main control board and still have the same problem.
You may want to replace the evaporator thermistor (on top of the evaporator). This thermistor controls the defrost cycle. - The evaporator thermistor Part number: AP3185407
Originally Posted by: Gene You may want to replace the evaporator thermistor (on top of the evaporator). This thermistor controls the defrost cycle. - The evaporator thermistor Part number: AP3185407
Thanks for the help. Is it the FF Thermistor or the Evap Thermistor? And where is it located? Leonard
Originally Posted by: Gene ...You may want to replace the evaporator thermistor (on top of the evaporator). This thermistor controls the defrost cycle... All thermistors in this refrigerator are identical. Gene.
Originally Posted by: Gene All thermistors in this refrigerator are identical.
Gene. Problem is fixed. I changed the evap thermister and no change. Even after reinstalling the original computer. I then replaced the freezer and fresh food thermistor and now the referigerator will defrost by itself.
