2 Pages<12
abadfish66
#11 Posted : Tuesday, December 16, 2008 6:23:13 PM(UTC)
abadfish66
LoL :) about the sledge hammer...I think your problem may be something getting jammed in the pump impeller, you will need to remove the drain pump to check.
Jjpascoe
#12 Posted : Thursday, December 18, 2008 4:00:53 AM(UTC)
Jjpascoe
I took pump out and appears to be ok. Still the same problem. Is there a selanoid or switch that would keep the pump from draining at the right time. You mentioned a 5 minute limitation on the pump.
Any other ideas
John
2 Pages<12
