goelajay
#1 Posted : Wednesday, June 8, 2011 10:17:57 AM(UTC)
goelajay
When we turn on the fan, the fan works but outside when I check the unit, the fan isn't running. I tried pulling out the fuse plug but does not seem like there is a fuse. I was hoping it would a simple fix like changing the fuse but not sure what else to try. Any suggestion?
goelajay attached the following image(s):
icehouse
#2 Posted : Wednesday, June 15, 2011 4:27:39 PM(UTC)
icehouse
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
chinahorse
#3 Posted : Monday, August 8, 2011 9:09:24 AM(UTC)
chinahorse
I have a similar problem. My fan turns by hand fine. When I turn on the unit, the fan spins and then blows the circuit breaker. I replaced the breaker = same result. So it's not the breaker. Would a failed capacitor cause the fan to spin and then blow the breaker?
icehouse
#4 Posted : Monday, August 8, 2011 10:16:23 AM(UTC)
icehouse
Bad Fan Motor would do this.
chinahorse
#5 Posted : Monday, August 8, 2011 10:58:31 AM(UTC)
chinahorse
Thanks Icehouse. I just had a pro check the condenser with a meter and he says the condenser is bad = new A/C unit. Does that seem consistent with it blowing the breaker each time it kicks on?
Like I said, the fan actually seems fine. It will turn on and spin each time just before the breaker blows.
icehouse
#6 Posted : Monday, August 8, 2011 3:20:20 PM(UTC)
icehouse
The fan motors winding expands as it is running causing it to short thus blowing the breaker.
Why can't you replace just the fan motor ? :confused:
icehouse
#7 Posted : Sunday, October 9, 2011 7:37:17 AM(UTC)
icehouse
:confused: fsx18cm6 no such model number. Re check and post. :)
Jaronbaer
#8 Posted : Tuesday, November 22, 2011 12:45:08 AM(UTC)
Jaronbaer
Buy G Star And Save Big - Low US Shipping & Fast!Summer collection now on sale. Save up to 70%. Shop now!Low Prices On G Star. G Star Reduced! Buy Save on Wholesale G-star Find NexTag Sellers' Lowest Price! And Save Big Designer Closeout Sales Buy Direct from China Factories. Sale Prices Latest Fashions and Styles on Sale Name Brands on Sale!
Guest (5)
