goelajay
#1 Posted : Wednesday, June 8, 2011 10:17:57 AM(UTC)
goelajay
When we turn on the fan, the fan works but outside when I check the unit, the fan isn't running. I tried pulling out the fuse plug but does not seem like there is a fuse. I was hoping it would a simple fix like changing the fuse but not sure what else to try. Any suggestion?
goelajay attached the following image(s):
icehouse
#2 Posted: : Wednesday, June 15, 2011 4:27:39 PM(UTC)
icehouse
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
chinahorse
#3 Posted : Monday, August 8, 2011 9:09:24 AM(UTC)
chinahorse
I have a similar problem. My fan turns by hand fine. When I turn on the unit, the fan spins and then blows the circuit breaker. I replaced the breaker = same result. So it's not the breaker. Would a failed capacitor cause the fan to spin and then blow the breaker?
icehouse
#4 Posted : Monday, August 8, 2011 10:16:23 AM(UTC)
icehouse
Bad Fan Motor would do this.
chinahorse
#5 Posted : Monday, August 8, 2011 10:58:31 AM(UTC)
chinahorse
Thanks Icehouse. I just had a pro check the condenser with a meter and he says the condenser is bad = new A/C unit. Does that seem consistent with it blowing the breaker each time it kicks on?
Like I said, the fan actually seems fine. It will turn on and spin each time just before the breaker blows.
icehouse
#6 Posted : Monday, August 8, 2011 3:20:20 PM(UTC)
icehouse
The fan motors winding expands as it is running causing it to short thus blowing the breaker.
Why can't you replace just the fan motor ? :confused:
icehouse
#7 Posted : Sunday, October 9, 2011 7:37:17 AM(UTC)
icehouse
:confused: fsx18cm6 no such model number. Re check and post. :)
Jaronbaer
#8 Posted : Tuesday, November 22, 2011 12:45:08 AM(UTC)
Jaronbaer
Buy G Star And Save Big - Low US Shipping & Fast!Summer collection now on sale. Save up to 70%. Shop now!Low Prices On G Star. G Star Reduced! Buy Save on Wholesale G-star Find NexTag Sellers' Lowest Price! And Save Big Designer Closeout Sales Buy Direct from China Factories. Sale Prices Latest Fashions and Styles on Sale Name Brands on Sale!
