2 Pages<12
kayakcrzy
#11 Posted : Tuesday, November 16, 2010 2:47:54 PM(UTC)
kayakcrzy
Originally Posted by: nimster64 Go to Quoted Post
I have another problem with my dryer. it turns one and spins but the heat wont come on. I replaced the two coils and it worked great but it gave up on me again LOL. what part do you think I may need? please send me an invoice so I can purchace the part. my cloth is piling up again. Thank you for all your great advice and parts.
I need a model #. Tom
nimster64
#12 Posted : Tuesday, November 16, 2010 4:23:50 PM(UTC)
nimster64
same dryer heres the info. thank you
here is the info on the dryer
mod:Model lgn2000jq0
ser:mk3508428
type:bwsr-nat-1206006-cv22
gas type 120v 60hz 6a
nimster64
#13 Posted : Wednesday, August 3, 2011 6:59:31 AM(UTC)
nimster64
Hi, tom my dryer is not working again LOL. ok this time it was making a loud noise I was not sure if it was just the belt makeing the noise but the motor finally gave out. i open the door and trip the switch and push the on button and it just goes bbbuuuuzzzz and click. so I think it is the motor what do you think it is? do you also recomend to replace the belt while I have it off? also should I replace the switch to turn it on the push button on switch?
heres the dryer info
Whirlpool 7 cycles imperial series
mod:lgn2000jq0
ser:mk3508428
kayakcrzy
#14 Posted : Wednesday, August 3, 2011 2:47:03 PM(UTC)
kayakcrzy
It sounds like the motor is bad. Did you try to spin the drum and see if it spins free.? If you have some one else around, what I want you to do is open the dryer door, and push in the door switch, and hold it in, and have someone push the start switch, and I want you to spin the drum, and let me know if it starts or it try's to start. Tom.
nimster64
#15 Posted : Wednesday, August 3, 2011 5:34:00 PM(UTC)
nimster64
Originally Posted by: kayakcrzy Go to Quoted Post
It sounds like the motor is bad. Did you try to spin the drum and see if it spins free.? If you have some one else around, what I want you to do is open the dryer door, and push in the door switch, and hold it in, and have someone push the start switch, and I want you to spin the drum, and let me know if it starts or it try's to start. Tom. ApplianceEducator.com
ok I did it and it didn't want to spin till i helped it and it made a loud screaching noise. can you send me an invoice so I can order it asap. :) I need to do laundry. your always a great help. 100% in my book.
nimster64
#16 Posted : Wednesday, August 3, 2011 5:37:01 PM(UTC)
nimster64
oh yea after i helped it spin it stayed spinning till I let the door switch go.
kayakcrzy
#17 Posted : Thursday, August 4, 2011 5:24:02 AM(UTC)
kayakcrzy
You then need a motor!!! Tom
Guest (6)
2 Pages<12
