AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
whirlpool dryer turns on heats for 5 min and and keeps turning but not heating?
Originally Posted by: nimster64 I have another problem with my dryer. it turns one and spins but the heat wont come on. I replaced the two coils and it worked great but it gave up on me again LOL. what part do you think I may need? please send me an invoice so I can purchace the part. my cloth is piling up again. Thank you for all your great advice and parts. I need a model #. Tom
same dryer heres the info. thank you here is the info on the dryer mod:Model lgn2000jq0
ser:mk3508428
type:bwsr-nat-1206006-cv22
gas type 120v 60hz 6a
Hi, tom my dryer is not working again LOL. ok this time it was making a loud noise I was not sure if it was just the belt makeing the noise but the motor finally gave out. i open the door and trip the switch and push the on button and it just goes bbbuuuuzzzz and click. so I think it is the motor what do you think it is? do you also recomend to replace the belt while I have it off? also should I replace the switch to turn it on the push button on switch? heres the dryer info Whirlpool 7 cycles imperial series mod:lgn2000jq0
ser:mk3508428
It sounds like the motor is bad. Did you try to spin the drum and see if it spins free.? If you have some one else around, what I want you to do is open the dryer door, and push in the door switch, and hold it in, and have someone push the start switch, and I want you to spin the drum, and let me know if it starts or it try's to start. Tom.
Originally Posted by: kayakcrzy It sounds like the motor is bad. Did you try to spin the drum and see if it spins free.? If you have some one else around, what I want you to do is open the dryer door, and push in the door switch, and hold it in, and have someone push the start switch, and I want you to spin the drum, and let me know if it starts or it try's to start. Tom. ApplianceEducator.com ok I did it and it didn't want to spin till i helped it and it made a loud screaching noise. can you send me an invoice so I can order it asap. :) I need to do laundry. your always a great help. 100% in my book.
Originally Posted by: nimster64 ok I did it and it didn't want to spin till i helped it and it made a loud screaching noise. can you send me an invoice so I can order it asap. :) I need to do laundry. your always a great help. 100% in my book. oh yea after i helped it spin it stayed spinning till I let the door switch go.
You then need a motor!!! Tom
Dryer Repair
