Jeffh333
#1 Posted : Wednesday, July 27, 2011 8:28:30 PM(UTC)
Jeffh333
I will be replacing the complete microwave door for a GE JVM1630W 004. OTR model. How do I do this?
Thanks.
Joe / APP Team
#2 Posted : Thursday, July 28, 2011 6:42:28 AM(UTC)
Joe / APP Team
Thanks.
Jeff,
Here's the basic door removal/replacement procedure for your brand microwave, it ought to get you through the repair.
Good Luck,
To Remove Door:
1. Remove power, top grille and short out capacitor
2. Remove the 4 (2 on top & 2 on bottom) 5/16" head screws
on door hinges and #2 phillips head screw on top.
3. Door will pull away from unit with the hinges attached to
the door.
4. When reinstalling door reverse procedure and a
to the control panel before securing door hinge screws.
NOTE: Door on a microwave oven is designed to act as
an electronic seal preventing the leakage of microwave
energy from oven cavity during cook cycle. This
function does not require that door be airtight, moisture
(condensation) tight or light-tight. Therefore, occasional
appearance of moisture, light or sensing of
gentle warm air movement around oven door is not
abnormal an do not of themselves, indicate a leakage of
microwave energy from oven cavity. If such were the
case, the oven could not be equipped with a vent, the
very purpose of which is to exhaust vapor-laden air
from oven cavity.
