I will be replacing the complete microwave door for a GE JVM1630W 004. OTR model. How do I do this?
Thanks.
Originally Posted by: Jeffh333 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I will be replacing the complete microwave door for a GE JVM1630W 004. OTR model. How do I do this?
Thanks. Jeff, Here's the basic door removal/replacement procedure for your brand microwave, it ought to get you through the repair. Good Luck, :) :) :) To Remove Door:
1. Remove power, top grille and short out capacitor 2. Remove the 4 (2 on top & 2 on bottom) 5/16" head screws on door hinges and #2 phillips head screw on top. 3. Door will pull away from unit with the hinges attached to the door. 4. When reinstalling door reverse procedure and a to the control panel before securing door hinge screws.
NOTE: Door on a microwave oven is designed to act as an electronic seal preventing the leakage of microwave energy from oven cavity during cook cycle. This function does not require that door be airtight, moisture (condensation) tight or light-tight. Therefore, occasional appearance of moisture, light or sensing of gentle warm air movement around oven door is not abnormal an do not of themselves, indicate a leakage of microwave energy from oven cavity. If such were the case, the oven could not be equipped with a vent, the very purpose of which is to exhaust vapor-laden air from oven cavity.
