lokahiboy
#1 Posted : Wednesday, July 20, 2011 4:39:50 PM(UTC)
lokahiboy
Dryer was found with very hot clothes and hot dryer! I have checked the exhaust and lint holder which are clear. After reading threads is the "cycling thermostat" the first thing to change? Thanks for any help you can give.:confused:
#2 Posted : Friday, July 22, 2011 4:49:43 AM(UTC)
Replacement parts for WHIRLPOOL LEC6848AQ1 ELECTRIC DRYER | AppliancePartsPros.com
First I would check the heating element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high.
Next I would check the internal heating element in the cycling thermostat (thermostat heater in the wiring diagram.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LEC6848.pdf (92kb) downloaded 6 time(s).
lokahiboy
#3 Posted : Sunday, July 24, 2011 12:41:04 PM(UTC)
lokahiboy
Thanks Denman for all your help. Replaced the Cycling Thermastat which fixed the problem
#4 Posted : Sunday, July 24, 2011 5:35:44 PM(UTC)
You are welcome.
jlhebert
#5 Posted : Tuesday, August 30, 2011 7:29:27 AM(UTC)
jlhebert
Hi,
trying to solve the overheating problem of my quite new Whirlpool dryer, I changed both the cycling and high-limit thermostats. I already changed the thermal fuse since the 1st problem was no heating at all.
Since I changed those 3 parts, the dryer never stops heating up, even at 'Air only' position on the panel.
My question : I understand that the thermostat might cut at 150F, but since there are Low, Med, High temperature settings, there must be somethign in the dryer that cuts off at lower temperature than this 150F ? I would suspect this device to be broken since the element still burns at 'air only' position...
Any help will be appreciated. Thanks in advance
- Jean-Luc
#6 Posted : Tuesday, August 30, 2011 3:05:00 PM(UTC)
jlhebert
Please start your own thread using "Post New Topic"
Unless your model number and problem is exactly the same it will just confuse things.
Does sound like a grounded element, so I would start there.
