isaac1
#1 Posted : Tuesday, July 19, 2011 10:54:25 PM(UTC)
isaac1
my GE range my circuit breaker tripped and when i reset it my display only comes on when i turn the infinite knobs and my range top nor oven works. when i turn the infinite knob off the display goes out also. what could be wrong my model # is (JBP25BM1WH)
#2 Posted : Wednesday, July 20, 2011 2:12:07 AM(UTC)
I cannot find any info on the given model number.
It sounds like a power problem.
The stove top and oven are usually wired as separate entities so if both go out it is usually a problem with the house electrical or the power cord.
The elements run off of 240 volts but the lights and display/control board is 120 volts. What may be happening is that one side of the line is out and when you select an infinite switch the other side of the line is feeding back through a component and powering the display.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If you find a problem be sure to take a look at the wiring in the unit to ensure that you do not have a short somewhere.
