washer wont agitate. everything else seems to work, including spin cycle. when in agitate mode you can hear a low humming. if i turn the motor belt by hand, one way, basket turns ,the other agitator turns. the agitator coupling seems good. thanks krf
If someone can help me please read on to page 2. I have tried everthing that makes sense to me. Help!!! thanks KRF
Originally Posted by: KRFhenco ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) washer wont agitate. everything else seems to work, including spin cycle. when in agitate mode you can hear a low humming. if i turn the motor belt by hand, one way, basket turns ,the other agitator turns. the agitator coupling seems good. thanks krf Did you ever get this fixed? I have the same problem .. spin cycle works, water drains , but agitator will not rotate .. spins freely clockwise .. but not counter clockwise.
no i havnt got it fixed yet. im taking motor capacitor to get it checked. my motor belt will turn both ways if you turn belt by hand.
Have you taken the agitator off to see if the shaft, goes back and forth in the agitation cycle? Tom
yes .. the motor does not even move. it just hums in the agitate mode and gets hot. the motor only kicks in when the spin cycle starts. something wont let the motor reverse. thanks kenny
Then the transmission is locked up. Buy a new washer. Tom
if the tranny is locked up why can i turn the motor belt one way the basket moves and when i turn the belt the other way the agitator moves? Kenny
also.. this washer is just a year and a half old. not happy with ge
When it goes into agitation, does the motor continuw to run, or does it cut off. Also try taking the belt off, and when it goes to agitate, does the motor run? Tom
when in agitate mode the motor does not move, just hums and get hot. i will try with belt off. good idea thanks.
