GregF
#1 Posted : Friday, November 28, 2008 9:56:24 AM(UTC)
GregF
My touchpad display panel went out on my microwave, so I purchased a new one.
To replace I need to remove the circuit board from the old display panel frame. I was able to remove all connections except one--there is a strip of clear plastic about 1.5" wide with circuit boad connections inbedded in it, and it is plugged into a connection in the circuit board. I cannot seem to get it out and don't want to damage it. What is the trick to remove, then re-insert the new strip on the replacement?
abadfish66
#2 Posted : Friday, November 28, 2008 9:59:05 AM(UTC)
abadfish66
There should be a lock on that connection, either by pulling up on both sides, or pushing the locking clip to unlock it, then pull the ribbon cable out.
#3 Posted : Saturday, November 29, 2008 4:30:04 AM(UTC)
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16023056.pdf
And the tech sheet for this model
http://www.servicematters.com/m...ibrary/docs/16026272.pdf
The manual has info about the ribbon cable connectors.
