phx1hab
#1 Posted : Friday, June 17, 2011 7:41:09 AM(UTC)
phx1hab
I noticed my refrigerator not getting very cold and my freezer stuff was starting to melt. I pulled off the back panel inside the freezer and the whole thing was completely frozen. I defrosted it overnight and and it worked for a while and now its all frozen again. I don't want to buy a new refrigerator, any ideas? Thanks.
richappy
#2 Posted : Friday, June 17, 2011 8:49:09 AM(UTC)
richappy
If the compressor and both fans running, I would pull the cover off the motherboard in the back, unplug fridg and pull off the 3 pin power connector, then put a wire jumper between the two connector pins that mate with the motherboard labeled pins line and def. Plug in fridg., if it now defrosts, you have a bad motherboard,AP4436216 If no defrost, probably a bad defrost heater.
