I have a frigidaire FSE747GES0 that is making a slight squealing noise when it is running? I have to mamualy start the drum to spin and it will run for about 40% of the time then it will stop and then I will have to restart it?
What do i need? Rear bearing and maybe the motor
When replacing the Rear bearing and or motor what other parts should be replaced while I have it apart? This is for perventive measures.
Where can I get a repair manual for this model? How do you take the covers off to replace the parts?
The bearing in the back is probably shot and it's causing a strain on the motor and it's over heating, then shutting down. Here's the breakdown Model FSE747GES0Nat
You probably have a clogged vent to the outside, and have a bad motor, and need to replace the rear bearing. I would replace the dryer. But before you do, chech the vent to the outside. Tom ApplianceEducator.com
